Builds Benjamin’s 3D Prints Build (20 Viewers)
@BenCC & others,
I'm interested in ordering MAKE 7 V1, but I need to know which elements of the build are/aren't included? Is it just the housing? If so, are some 12V or USB sockets better than others?
Also, I'm willing to learn and work, but I'm no electrician. Does anyone have diagrams or instructions for rewiring?
Thanks so much!
Will
Thanks again Ben for the great work!
Make 7: Rear Cooler Switch Hole Mounting Plate
7.1 Overview of the Final Product
Make7 V1
Note: Make7 V1 mounts two 12V socket devices, such as
12V Socket
USB Extension
USB Charger 2.1 A
USB Charger 4.8A
Make7 V2
Note: Make7 V2 mounts one 120V outlet and one 12V socket device. The Toyota part number of the 120V outlet is 85530-35050-C0. The harness can be found here.
Socket device CAD courtesy of Alexander Polyakov at Free CAD Designs, Files & 3D Models | The GrabCAD Community Library
7.2 Introduction
This mount it to replace the blank panel or the radio control unit at the back of the center console. It mounts two car socket devices.
7.3 Design and Fabrication
Multiple prototypes have been made to test the dimensions, surface printing method, and materials, etc.
7.4 Purchase List to Complete the Installation
120V Outlet: 85530-35050-C0
Wire Harness (Toyote OEM 12” In-Cab AC 120V 400W Power Outlet Plug-N-Play Wire Harness | KTJO 4x4 - https://www.ktjo4x4.com/product/toyote-oem-12-in-cab-ac-120v-400w-power-outlet-plug-n-play-wire-harness/56?cs=true&cst=custom)
12V Socket
USB Extension
USB Charger 2.1 A
USB Charger 4.8A
Note: The following figure shows how you remove the mount and how not to.
7.5 Purchase Link
$30 (Tan, Grey, Black)+Shipping
PM for direct Paypal payment.
Stupid question maybe, but where are you getting power for the 12v outlets? I plan on getting one of these to add some usb ports but I also want to find some power under there to tap into for my two headrest monitors. Are you tapping into existing wiring? Or are you running wiring with an add-a-fuse or something?
Ben, I PM'd you. I want one of your M35(?) SP-9100 mounts asap.
Make 4 V3: Multiple Rock Switches DEEP Mount for Toyota Land Cruiser 100 Series
M4V3.1 Overview of the Final Product
M4V3.2 Introduction
This make is revised based on M4V2 . Switch pockets are pushed out to give some extra clearance behind the mount. See the following two pictures for comparison between the revised version (M4V3 Red) and the previous version (M4V1 Blue).
M4V3.3Purchase List to Complete the Installation
Rocker Switches
Panel Plugs
M4V3.4 Purchase Link
$75 + USPS Priority. Printed in tan or grey ABS or PETG. PM for direct Paypal payment.
50% discount if you purchased M4V1 or M4V2.
is @BenCC still able to take orders? what do you do email? will you post international
Ben…or everyone. I’ve been trying to install the cup holder in my 2006 LX 470 and have run into a problem. There is wiring on the drivers side/by the e-brake that is not allowing the cup holder to install. Has anyone else run into this? How do I resolve this issue? I have a CD changer in the center console…is wiring for cd changer?
This was a clip. The cupholder fit once the clip for the wiring was released. I'm curious, is this exclusive to an LX 470 or maybe specific years? Another question, if others have installed this cupholder and have run into this same issue what they did with the wiring? Seems to me you'd either have to leave the wiring dangling or create a new way to fasten it lower in order to install the cupholder.
