Builds Benjamin’s 3D Prints Build (21 Viewers)
I am still trying to buy a used unit on eBay. Didn’t find one.
Ben, I'd be happy to remove and send you mine. I'm not positive if it's stock or not. Let me know your thoughts.
I have seen at least thee different styles of the DVD units. Dealers across the states might have just installed whatever they got. My concern is the bolt pattens they used.
Mine is different too and it looks like they just drilled into the metal to mount it. I can send pictures, measurements if that helps.
good idea. The part is printed facing down. So adding a feature would prevent this print configuration. I can add a bolted on raised feature.
Makes sense. Maybe just make the opening on the face have a gap around the switch and then print a second part that would install from the rear and protrude a few mm on the front. Just sandwich the second piece between the switch and the faceplate.
thanks. Not completed yet. Need to tweak some small features.
i'm definitely down for this... SAEDOT Fogs for me too to replace my factory fogs running in a TJM bumper! if i can get a 2nd light for flood/ditch, that would be a bonus, but I'll take what I can get!
