Wanted Bellhousing for 1984 FJ60
Status
Not open for further replies.
portland, oregon
  1. 60 Series
My upper bellhousing has a crack so I’m looking to source a good one. Thanks!
I have a later one, the stamped 3FE bellhousing. I'm pretty sure it would work. The clutch fork is slightly different. Ask orangefj45 for sure.
I have a lead on one already but not sure if it’ll pan out. How much would you want for it?
Mind if I ask if you know how the old one cracked. In 38 years of wrenching on cruisers I’ve never heard of one cracking before, especially on a 60 where the weight of the transmission is fully supported.
I was hoping no one would ask. The transmission was on a transmission jack (a cheap one from harbor freight because I don’t plan on doing this type of work regularly) so it was fully supported. I was trying install it because I had just replaced the clutch. I couldn’t get it to slide in even though I had the holes on the transmission and bell housing aligned, so I tried “walking” it in by getting longer bolts that would reach the Bellhousing and slowly rotating corner to corner on tightening the bolts. The bolts got hard to turn at times but I figured that was because I was rolling the transmission towards the Bellhousing. I was in the middle of cranking one and heard a crack. I stared inspecting things and found a vertical crack that split a bolt hole where the lower cover attaches to the Bellhousing. I was really surprised this happened because I wasn’t using an extender, just a normal ratchet. It’s definitely a learning lesson though. I’ve had lots of this on this truck.
the later bellhousing 3F is not compatable with his currrent crossmember
seen this done before
the trans should slide right in when aligned correctly
should be no need to use the bolts to pull the trans into place
I saw someone did this about 10 years ago and you supplied them with a new housing. That made me feel a tiny bit better about things.
I did something similar with a 22RE in a 2wd Mini truck. I used the bolts to walk it in and I broke the side braces of the bellhousing. I readjust the clutch and it slide right in and I had to find a brace in the junkyard.
Note to all: I test fit the pilot bearings on the transmission input shaft before installing the bearing in the engine. If it doesn’t fit, I dress the tip of the transmission until it does.
I’ve never had an issue installing a transmission since.😉
@dsagona Might want to verify the production month of your 60 as 84 is right on the border of when the bellhousings changed.
FJ62 started 11/84 in most markets. In the US FJ60 continued until 8/87. 4/85 the 3F bellhousing started in the US. Easy to recognized by the 3F case in the later bellhousing. Also looking from the back side can see the top of the opening for the transmission is rotated slightly clockwise. The rotation is the reason the crossmember has to match the bellhousing.
Yes. I am aware of all of that
I have one off an 82’ available in Los Angeles. Willing to ship
Status
