SOLD BC: 1982 BJ60 'G' trim, the 'Wirrell Wagon'
Year
1982
  1. 60 Series
Mileage
667000
Color
Blue
Hi Everyone,
Many of you who frequent the diesel forums may remember Charles, a long time admin and a member of our Coastal Cruisers club www.coastalcruisers.ca
Charles passed away ten years ago and his truck remained in his family until 2 years ago when I acquired it. My plan was to 'repair it to factory' as it needed some work to get it more road worthy. I say 'more' in jest because Charle's son just drove it about a thousand miles from the Yukon with no charging system, questionable brakes and worn shocks. lol. These trucks are tough.
There are several threads on Mud from Charles describing all of his work on this truck in Guatemala and Africa, it transported the family all over the world for 35 years they owned it.
Here is the current specs
Later model 3BII NA diesel engine from a Hyno truck (installed in Africa) mated to a Toyota 5spd transmission. Rotary fuel pump.
Power steering and brakes
A/C
Headlight washers
Original interior
Body is the best I've seen. small bondo patch in rear driver's corner.
Body was brown, repainted blue many years ago
Frame is solid, only surface rust and lots of african red dirt stain (it's actually everywhere lol).
80l long range tank
Aussie rear locker
Three VINS match the paperwork. Easy import to USA. This is originally a CDN truck.
Most of my work was to fix the electrical system which had decades of accessory wiring and old mystery components. It is returned to factory except that I put in a manual glow switch and disconnected the superglow for simplicity.
Newer alternator
New shocks and brake drums. Serviced all brakes,
Tires have great tread but are several years old now as it has seen few miles in the last decade
Factory am/fm radio
Period CB with 9' whip antenna
Winch is removed as motor was shot
New fuel injectors
New ebrake cable
Everything works except rear wiper switch I'm still troubleshooting. Rear squirter works. Motor works just not with the switch.
Good compression. Snorkel.
Throttle linkage fixed up, 65mph on flat highway, 5th gear, @2500rpm
Could use two new batteries but they hold a charge and start overtime. Those interstates last a long time.
Runs, drives, steers, and stops. Daily driving now.
Asking $12kUSD
You can drive as-is, albeit slowly! But this truck really should be restored as it is a very complete with very little rust.
More pics.....
More pics....
Last set of pics
At idle, at operating temperature.
Post up any questions! Thanks for looking! Truck is located 5 miles north of Sumas Wa.
Frame pics as requested. Has long range tank so not a lot of space between frame rails. Also lots of red Africa dirt!
Engine swap thread from 2012!
It's funny I saw the thumbnail pic and thought "that looks like Charles' truck" and turns out I wasn't wrong!
I don't remember if he has the 60 or his 55 the last time I saw him around 2009 or so.
Good luck with the sale!
Dan
Great cruiser and seller. Hope to see it find a new owner within the community so it can continue on its story.
Just an update. I've been continuing to work on maintenance and other small items
Throttle linkage has been repaired and works much better. No more binding!
Finished changing the diff and transmission and transfer case fluids
Now, onto new exhaust.....
:beer:
Pics updated. Daily driving now with new injectors and side exit exhaust. Will tackles knuckles this winter I think.
2.5 inch with high flow through, who knew a 3B2 could sound good. Lol. I'm not a professional mechanic by any means so I'm not afraid to bring in the pros from time to time.
Sale pending
SOLD! To a cruiserhead near me.
