THESE FUTURE POSTS ARE TO DOCUMENT THE REST OF THE PROJECT, ESPECIALLY THE FACT THAT THE TRUCK ARRIVED IN THE USA THIS WEEK... SORRY BUT NOT SORRY, enjoy.
For the brake system, we replaced all components except the front disks, rear drum, and front calipers; but we replaced all components for the rear drum brake, the hand brake cable, the VALVE for LOAD SENSING PROPORTIONING, and more.
BRAKE PARTS
9094702612 hose brake, lh
9094702613 hose brake, rh
9094702a18 hose, brake, front
9094702933 hose, brake, rear
4791060090 valve assy, load sensing proportioning
4792060090 spring assy, load sensing
4641060431 cable, parking brake
9050723014 spring tension, parking brake shoe return rear, set of 4
9050612068 spring tension, parking brake shoe return, set of 2
9050620033 spring tension, parking brake bell crank, set of
4774860010 spring anti-rattle, set 2
9024008042 pin, handle brake, set of 2
9328016022 screw, set of 2
4761235040 lever, parking brake shoe, rear brake, LH
4761135040 lever, parking brake shoe, rear brake, RH
9050120012 spring, shoe hold down, set of 4
4744930020 cup, brake shoe hold down, set of 8
4762835020 bracket, rear brake bellcrank, set of 2
4763335020 boot, parking brake bellcrank, set of 2
4764460010 lever, automatic adjust, rear brake, LH
4764360010 lever, automatic adjust, rear brake, RH
4762460010 crank, parking brake bell, RH
4762560010 crank, parking brake bell, LH
9021307010 washer, c, rear brake
9021306013 ring, e, rear brake
4761660010 wire, parking brake, set of 2
4762660010 pulley, parking brake segmental, set of 2
4706260011 adjuster, shoe rear brake, LH
4706160011 adjuster, shoe rear brake, RH
9050618031 spring tension, rear brake shoe return, set of 2
9050626014 spring tension, rear brake, automatic adjust lever, LH
9050626011 spring tension, rear brake, automatic adjust lever, RH
This guy
Additionally, while the mechanical team works on the chassis, the body shop team is cleaning the underside to restore it to its original condition. The main chemical that I found in my city is this powerful product:
