1992 FZJ80 GCC Edition - 32X11.5R15 Tires
colorado
Has anyone installed 32X11.5R15 tires on a 1992 FZJ80 GCC Edition? Looking for photos. Did the 11.5 width rub at all on a stock non-lifted rig?
Thanks,
Based on the tires I have run on my 94 I don’t think they will rub.
But how wide are those wheels 7” ? If so 11.50s may to wide for the wheels.
They are the 7JJX15 ET8 wheels. 7". I am looking at the
Falken Wildpeak A/T4W All Terrain LT32/11.50R15 113R C Light Truck Tire​
IMO those tires are to wide for a 7" wheel.
Falken does recommend on their tire chart 8-10" rim width as the approved sizes. And sometimes you can find tire shops that are finicky about installing them.
I've run 12.5" wide on a 7.5" factory wheel and Falken says it needs to be 8.5" minimum. Places like walmart or discount might not mount it, but most mom n pop or independent tire shops will.
11.5" tires on 7" wide wheel is likely perfectly fine and you can probably find examples on the forum of people doing it if you look long enough. But of course it's a "run at your own risk" type of thing. You could try finding a set of the factory 16x8 wheels if you are trying to stay OEM.
