axle breathers
Read the writeup theo linked- you don't want the stock "breathers" anyway.
Any 1/8" NPT fitting will thread in where the stock breathers were. Use that to run a line somewhere high (firewall), this will keep water out and oil in your axles much better than the stock setup.
nuclearlemon said:
get a piece of hose and clamp it to the nipple o fyour old breather...route up high...done.
This kind of works, but does not get rid of the troublesome one-way valve, nor the tiny orifice in the stock breathers.
I removed a stock breather (which I had previously pried the cap off of) and heard a disticnt hiss of pressure release as I unscrewed it.
"Standard" nipples? Ige, I thought yours would be "Heavy Duty".....
Nipple
Ed
Someone's feelin' brave.
