Auxiliary Fan Install
It's really the only clean place to put it on a 93-94. The factory alarm is Junk anyways JMHO. ;)
Cheers
Sounds like I need to read up on removing the alarm. Thanks, all.
It's really pretty easy and straightforward.
i got mine installed. Best thing ever in this Vegas heat. Immediate difference in cooling down the interior.
One question: I wired according to the diagram & the light stays on even when the fan is not on. How to I correct this?
Before, after, & light on when in off position photos. Ignore the dangling red & yellow wires. I have yet to install the button for my KC lights. I’m horrible at wiring. Figured I’d get the lights button wired once I got the fan button in, but the fan button was such a plug & play idk what to do with the lights. Plus the LED always stays on, hence my question & hence my dangling wires. Lulz
If your switch light is staying on swap terminals #2 & #3 on the switch
Ordered…will add to the pile of parts I’m still installing
So i have the fan but not installed yet and i do have a modded fan clutch. So I wouldn't need to install the aux fan?
The aux fan won't really help with overheating but it can make your AC vent temperatures cooler when you are crawling (even with a modded fan clutch). Unless you live in Hawaii apparently.
Nice! Appreciate the answer, that's pretty much what I got it for was to have it just in case the ac wasn't staying cold during slow runs in the summer. Thanks!
So finally decided to install this kit. But I ran into the issue tht I have a winch in there with a stock bumper. So the brackets don’t work at all. This was the best I can do. I’m not a mechanic or a fabricator so this it lol. My question here is for LandCruiserphil do you think the way I did the set up? You think it might still work ?
My winch was in the way also and I had to move it up similar to what you have done.
The fan works as it should 😉
IMHO the fan should still work, the zip tie mounts are concerning, I would at the least use some bigger ties
I reworked my mount so that is was still mounted as designed just up away from the winch.
AJFCJaUYfKNxJ2jlIdeT_tZPoGep79Om656yWD7D4ICEMbOZvD5YtgRab9dekTolAICX9z3Qu-17TC9ToTHv_PZUHrGrbgRCetl_WbsT6ta4Rd8_7MaTfbTlKVcDTgFEwo2cZiHqf7NwzEww1OlpD8DkOHyrJzm8zlG05rJGNVmmUU-0Ivkz58_mHvKFFLrzLEaxG4nxmv4qWwMe1AVXGFuXPld_sjdsS3aZtZiSPQmRKL9JEoY9ZMtVGp-KYa3f_WjAAi4aU_vjGirETp7K4kx2U9_jNQyxzhgF6Y4_FDL9VmfLz0Rup4bZ77fdFEJJoanLmg6W-WzWZkf4JltJLMyFL-gWF62SDoQaRFZWA9G-9h-5rCJmTNgPnISpkA3BR-FnSbXJNva1wy5tXNBpFnve4xcE4FtTQB_O-8mkSPQvufy6q96AHclNiaWKqNKYAKximUwP5X-5zqw0U6Pvu_J3AT7ytQ_1CGyLD9Y72zL22h4R4iEX7WgMC59XfWwsBCMYonePnYZpzLBPrqiPwRBJoRp3wTIkf7kY4MNOHz5pQkTXhJA0KWcin5KNIpQpagW-sFYYeUmwOt1sMNPRQmwTT7pWkE6HPrrqfs9h8415T5HPVb-ni6DI7v9_f7nmw8elqYsNa4tCtdHTUBW9ow0ZdghYvnXp8KtXKuebuGCpza6mjHdTNya21glr3CZkPdO7PCxjn_5fe05MAa5n7EE6Za0p3zlmQ6hL0prhiecuZqf0dznPPgpxfVfXoiRTA6aHihnFCkj1DuOt-8zRgJKqtOVZaI7TbvJDCnOmvZQd6Hxyk8vCsHm6hOHxaAx21BRL9RGImB5B8k8eEaTV2VtKGROE40Y8OvEaT_gGf0GOdN-uWV6JrKgpI0n4W8ZG2IlvaUnwgRpSjn2C1gzCaE3ds1pp5g=w704-h939-s-no
AJFCJaU__5zPe6D0_OWjgZqNPKJ5JE2_TFApUcQYZoqGiBrCUzGgGPBqywI5WMgnW4HlTgbTxvSqv5Oj9pS1wxI9ieNHaGmDCg3c4dmv5K0qY_yGu1Xpu9BlVGGfxwRscjX0ZGmZMaIua5GQa07x6S1UMOi152U4ha5I-seTV-ofpYSn34KE_X1GV3zruTb8M0j_GNMprOat5BysnDqko08FZi57VXpccjsC4aJ_nkrIeZ5j9FHofh1doSIWjuwIiVOgBEOj3dvxqRrb0HbsTw6FdoLx4Kz8Rt-wBz62gXrVQentqm5lwrUXIemLiEPifRmxpyY25xqe2oHRmcbt9I6iCizYlHBe1Cun1P_xt-p23hKJofud3kmeovM2PgHkq6e4xMrIDOo0RshPBZqPTkJ2FSHvBplG8cwx3kNKHlh09aBMnlWqeZ2QebgKSf5hMXVEnoJ3v-t5tJ_vQewL1wgLBnt0HAS8rLqjtqo2XKaSvKJOFvybwqdFDwDwZogDODSwEMobFNfOcgpVsInKgWHTNdwUocDJa4QyOCVr1Fu8h217v4O7RlaZ0cWGC1EtH1Zeie_sM2K2yE2At0C6yB-Pizsw9grH6Mh3U0kDsBCQzQ1_hEK7BbdG8Ks_9sqFXtBjVxuSf02rBEjFVc3ZFJVbl4-7u5HD7VD6tNIzAQfuxMHAfJwpDSey1dS36iI3IL4Qi9s-SeF_0QS95RNGriVPf-eiGCFEZdq67oaL9i1wucT9vF2uey4nh5KXUUEw20vyzzXiWFG7OD3a23jsBaoUy5Z03oIBKMlAEgx1mEj9oqqoEPAjJADAs7tij6fCJyUWj8jGTu4htoxl430gMIbgeFxhRcAdhmdvh4EgXJzanANkKH71WgIFYsvd9H7BK9IV8DVJjFTgeD1F2aeD5HEmIqk8iA=w704-h939-s-no
