And what is the result? better A/C or better coolant temps? Before/after?
I will be trailing this weekend. I’ll let you know. I literally just installed it.And what is the result? better A/C or better coolant temps? Before/after?
In general those fans won't help cool the motor.And what is the result? better A/C or better coolant temps? Before/after?
Says who? I ran Fordyce and Rubicon with a rigged 93+ Radiator and a single 13" puller elec. fan from Napa.In general those fans won't help cool the motor.
They do keep the AC cooler in low speed rock crawling or setting in traffic.
I well also leave it running if I stop on the trail to help with heat soak under the hood.
I find it helps more if I turn it on when I start the trail instead of waiting tell shes getting hot.
maxflateairsystems.com
Most everyoneSays who? I ran Fordyce and Rubicon with a rigged 93+ Radiator and a single 13" puller elec. fan from Napa.
220F ish avg on the trail. No shroud, no foam, no nothing... I did have 2 pusher fans up front running the entire time to help with additional cooling however. I wouldn't recommend doing that w/ the 1FZ-FE though!
What i was saying is, my auxiliary fan in the front of the coil was used to cool my AC , except it can be reversed. The only reason i was able to do a trail fix and continue was because my stock manual fan was broken when it made contact with the radiator. So what i was saying is, i would have been totally screwed have i not have 2 auxiliary fans up front for extra cooling, and i was able to use one of them to use it as a main radiator cooling fan.Most everyoneexcept you.
This thread is about a auxiliary fan and that’s what the poster installed
I’m sure that your system works but as the main fan it’s much bigger and your running two more in front.
Simply not the same.
The auxiliary fan people are using in front of the radiator are a smaller single fan
For reference my stock fan setup with a modified blue fan hub & 10% underdrive pulley keeps the ET down at 200* or below on the hottest and & hardest trails Fordyce,Rubicon etc., with AC blasting and the single auxiliary fan going.
I also said in general.
Read the link in post #225 states the same thing @LandCruiserPhil fan kit states
Won’t help with ET
This still has nothing to do with the question that I answeredWhat i was saying is, my auxiliary fan in the front of the coil was used to cool my AC , except it can be reversed. The only reason i was able to do a trail fix and continue was because my stock manual fan was broken when it made contact with the radiator. So what i was saying is, i would have been totally screwed have i not have 2 auxiliary fans up front for extra cooling, and i was able to use one of them to use it as a main radiator cooling fan.
My answerAnd what is the result? better A/C or better coolant temps? Before/after?
You also notice I say in generalIn general those fans won't help cool the motor.
Can you tell us that part number of that fan or where to find it? Looks great!i got mine installed. Best thing ever in this Vegas heat. Immediate difference in cooling down the interior.
One question: I wired according to the diagram & the light stays on even when the fan is not on. How to I correct this?
Before, after, & light on when in off position photos. Ignore the dangling red & yellow wires. I have yet to install the button for my KC lights. I’m horrible at wiring. Figured I’d get the lights button wired once I got the fan button in, but the fan button was such a plug & play idk what to do with the lights. Plus the LED always stays on, hence my question & hence my dangling wires. Lulz
That's not the experience I have had. My aux pusher fan cools the truck nicely when it's in the rocks.In general those fans won't help cool the motor.
Glad it works well for youThat's not the experience I have had. My aux pusher fan cools the truck nicely when it's in the rocks.
The fan we used with our 80 series kit is a 100 series fan.@LandCruiserPhil I believe the PO of my 80 had your kit installed, the fan is now dead. Any idea where I can source a new DEPO fan or an alternative brand that’s reliable?
