- Thread starter
- #161
Does that mean no advantage to fan on rad if running Wits' End blue hub?
Not so much in Hawaii where AC is not needed.
5/16" minJust curious what size drill bit I should be using to drill the hole for the upper bracket?
Thank you sir! Installing it right now in preparation for a move from Northern CA to Phoenix this weekend. Did the Landtank fan clutch last month so should be in good shape now.5/16" min
Have you ever hooked one of these up, with a kit like this?
Temp controlled and A/C override.
Adjustable Fan Controller Kit, Probe
Take full control of your electric cooling fan with the Mishimoto Adjustable Fan Controller Kit! This kit is applicable for any 12v electric fan and includes all necessary components for installation. This kit can be purchased with a probe-style temperature sensor or with a 1/8" NPT thread-in...www.mishimoto.com
Waiting on bracketsWhen will These be available again?
+1 for me, it's going to be 115 today in Vegas, I just moved here and it's time I order once it's available again for sure!W
Waiting on brackets
+1 - redoing my hoses and replacing the radiator. Please PM me when they are available LCP.W
Waiting on brackets
11” - from post #120What size fan is used for these? I think I have a few old ones in boxes from ATV etc,
Thanks
Dave
Phil’s directions suggest tapping into the “Wiper” fuse with an Add-a-Fuse.Not only for the fan but also some other switches power needs does anyone know what fuse is best to tap into for the ignition hot connection for the relays?
thanks
Dave
forum.ih8mud.com
I tapped the same fuse as post #5.Not only for the fan but also some other switches power needs does anyone know what fuse is best to tap into for the ignition hot connection for the relays?
thanks
Dave
