I'm installing an ARB compressor along with the lockers in my 75 fj40, what I was wondering is the compressor good for anything else other than the lockeers. Is it big enough to air tires or run tools. Any info would be great thanks
FirstToy said:I've been doing alot of research on this lately. ARB designed the compressor only to run lockers- it has a mini tank built in.
You can air up tires, I think many people have said it does that- just slow.
Better to have a stronger compressor for that (like a 100% duty cycle, ARB's is less than 30% duty cycle I think).
Not enough power or air reserve to run tools though. You need a seperate air tank (which people put in the front bumper or under the truck) or CO2 tank ideally for tools & airing up tires.
A little plug for me- I'm selling a new Viair compressor in the "for sale section"![]()
Velocity2 said:why not mount a larger compressor and make a tube style bumper and make that your storage tank?
Tigerstripe40 said:Well, I was on a run a few weeks ago with a guy who has a 10cfm york on his cruiser... In the time it took him to fill 1 tire with the york, I filled 4 of mine, and one of his with my CO2 tank...
I do have the Powertank valve, so I think that makes a difference.
Landpimp said:Been using my ARB compressors for YEARS to air up tires, its slow but it does the job, never burned one up. ....
trainrech said:CO2 is nice until you run out in the middle of a wheeling weekend. I'm running my ARB off of my CO2, but am strongly considering a 10 CFM York either in place of or in conjunction with the CO2.
cruiseroutfit said:Ditto, I have filled up dozens of tires with the ARB compressor. It is designed to be used as a tire inflator... they even sell it in a easy to carry case with 12V cable connectors. It is not a 100% duty cycle, so you can't run it for ever. I have CO2, but it won't be replacing my ARB comp anytime soon...
PS, I have burned up an ARB compressor... after filling it with sand & water (deep water)
Landpimp said:the older ARB comps had a pretty short duty cycle, think it was 5 or so years ago they upgraded it.
