llih said:
I used the stock rad, shroud and a flex fan for years. I live in the Mohave desert. I used to drive up and down the Cajon pass everyday with no overheating problems. That being said, I wonder how much the placement of the Chevy with relationship to the firewall affects the heating issue? I remember way back reading something about not getting enough airflow over the v8 when it was too close to the firewall. I also question how accurate some of our temp gauges are.
I am not sure about engine placement, but I do have some first hand experience about gauges reading wrong.
One thing I used to always hear from the old guy at the Speed Shop was that you can't make more power with out making more heat. He used to say this because guys would drop in a warmed over motor back into the same car it came out of and the motor would overheat and or run hot. Add a hundred HP and it's going to run hotter. The same radiator that worked before, was no longer good enough. GM used to have trouble with Corvettes overheating brand new, they were the LT1 versions that probably did not get a special radiator where as the stock 200 HP version would never over heat. It's not just F/2F running cold and V8's running hot. Souped up V8's run hot.
Having said that, I can totally see how one guy can run a mild stock V8 with the stock radiator no problem with good air flow due to engine placement and a very good stock radiator that flows well (not clogged or scaled up).
On the other hand, some other guy has a warmed over V8, too far back from the radiator and an old stock radiator that's full of scale or even a good stock radiator with too much HP in the small block for the stock radiator and in both cases it runs too hot.
It's not a black art; it's science. Too much HP = too much heat for that radiator to deal with. The back art part of it is taking engine placement and or airflow into consideration. Even then, it's not that hard.
If there is any one thing that amazes me is how many people have small leaks in their coolant systems that cause overheating. No matter how much radiator you have, if you a leak, it's not going to build up pressure. A leak at the thermostat housing or fill cap is not even going to loose much fluid but will loose pressure and not let the system work.
