I have done a complete rebuild on my FJ40 4/71 four wheel drum brakes.
New OEM master cylinder, all new steel braided lines except the right rear hose I cannot get off yet.
Rebuilt seven wheel cylinders had to buy one after market from MAF.
All new shoes and turned all drums. Bench bleed the MC then bleed all the lines. I have a good hard pedal. Adjusted each cylinder until wheel would not turn then backed off a few clicks.
I’m getting a hard pull to the left, almost a u-turn! Scary and not safe at any speed.
I have readjusted each cylinder several times with the same results. I pulled each drum off and checked each cylinder to make sure the pistons were moving and there were no leaks. If I back off the adjustment so there is no drag then my pedal goes down ½ to ¾ and the pull does not seem to be so severe. I tried backing off the adjustment on the left front and rear keeping the right side a little tighter but that did not seem to change anything.
I’m pretty much at a loss as what to do next. I’d really like to get the drums to work like they should.
Thanks for any insight as to what I should check or triple check.
Ken
Ken
