Romer said:I also think wrapping the exhaust is a good idea.
If you want it to rust away much quicker...
getting it ceramic coated to keep in heat=good idea
wrapping= bad
SWCruiser said:Scott,
Great info. On lxtremes vent- isn't that also a potential issue with dust (not on his particular truck, but generally speaking ).
I have another question- It seems venting in the opposite direction would allow for better venting of air flowing through the radiator but doesn't the absence of hood vents also control movement of dust from carrying up into the engine as the air must flow downward?
gnx7 said:Here is a basic mod I do on my road race cars: remove the rubber seal attached to the back of the firewall that seals to the hood. Great way to let air escape. It will work better at speed.
SUMOTOY said:....
personally, I believe more damage is caused by the engine driven fan sucking dust thru condenser and radiator cores. The military is starting to get a handle on this after a couple years of exposure/failure
SJ
Tools R Us said:Dust really isn't a problem in the cores as long as they are clean and dry it just sails right through, bigger stuff, sand can be a problem. For us sand is only a problem if your following too close, driving in someone's roost. For the military they may have problems with big close convoys, big sand storms, helicopters, etc. kicking up the bigger stuff.
Dusty said:People keep speaking of issues with the hood vents in terms of pressures atop the hood. But my truck doesn't have a problem with heat when on the highway. I would want the scoop/vent/whatever for when I am not moving like in stop and go or when wheeling.
this past weekend I was wheeling my truck in st george (got some 295/75/16 bfg's) when it was 110' outside. truck got as hot as 215' per my digital probe in the upper heater hose. In this case a hood scoop would have been helpfull to let the heat out. I wish lxtreme would post a part number for that scoop of his
I know the hottest point under my hood is just above the turbo because that is where the heat is discoloring the heat mat attached to the underside of the hood. i think I would want my vent there.
We need to differentiate between convection heat and radiant heat (which I did several months ago). Radiant heat off a turbo can be reduced by hood vents elsewhere, but that requires air movement. Once you shut the truck of with a hot turbo, it's radiant heat = Vent or afterrun fan.
Dusty said:I am concerned about when the motor is running. when idling along at less than 5mph there is so much heat under my hood that it is scary-especially if I open the hood after a boosted run in the sun. im not overheating when wheeling as I can live with 215 degrees. The motor will be fine at that temp especially with such mild loads associated with rock crawling. The worst part about this wheeling in 210' st George heat was that the ac condensor doesn't get enough air flow to keep the cab cool. Im finninshing up a Haden 12" fan instal and looking for some effective vents/scoops.
Again I dont care about scoop/vent dynamics at speed as heat hasn't been an issiue at speed this summer even when running the mojave in 100'+ just 2 days ago. this past year I replaced the fan coupler and thermostat before installing the turbo WITH INTERCOOLER and relocating the oil cooler. But the intercooler covers half the radiator and this is what is making my ac so innefective at stoplights. I need to get more air through the condensor and then out from under the hood.
You fellas with superchargers need to get intercoolers.
mot said:A little slow in responding, but thought I would show what are available in Japan, other than what LX has posted...
I've also seen guys putting some washers in the hinges close to the windshield to have that end be a little higher to reliese some hot air (not sure how well/poorly it or any of these work though).
Romer said:I also moved the lights to the top of the ARB. Now need to relocate the CB antenna.
Don't know if I am going to go through with relocating the radiator overflow bottle. Need a few more step #6's to ponder.
Here is the before shot
