Builds An Accidental Frame Off.................. (4 Viewers)
If I am not mistaken the breather has a spring and a ball in it to hold it closed. It pushes out and then burp then reseals. That is why you do not get water in during fording water. It may have an o-ring in there as well. It has been a while since I took one apart.
Mine doesn’t seem to have anything inside of it, maybe that’s the problem. It seems like it is just a cap crimped over the top kind of like an umbrella.
I might take one apart this evening, for tech purposes.
that’s how I always envisioned them. If there’s a spring in there it isn’t springing anymore - on any of my breathers.
i had my axle breather plug up on my 62 and it blew oil out the rear seals. that ruined my rear brakes so my fronts were doing more braking and warped the rotors. all because of a little breather. fix them and keep them working or run a line up higher than any water you’ll cross and let it vent!! it gets expensive chasing stuff like i did!
Okay so my 1972 has a plug or something of sort on mine. Looks factory and been on there a long time, I assume. Did they come with sort of breather "cap" like that? I have to rebuild the rear brakes anyway, so I will just run the breather up the aux tank hose like BMThiker 👍
i tied all my breathers together and ran them as one line high on the firewall and just put a valve cover breather on the line for my 40. easy to run lines there and i’ll never go in water that deep
Where did you source the fittings that you used in place of the breather at the axle? I'm assuming you used a hose barb fitting?
on the tcase I just ripped that top part/spring loaded off and pushed some heater/fuel line over the little stub and hose clamped it on. id imagine a barb would be more secure on an axle, but it take a a bit to pop that hose off and on the tcase it doesn’t get that much movement.
my axles are extended but honestly I don’t remember if it’s the same setup or Barbed.
This is at McMaster-Carr for $7.25 if you'd rather roll your own...
Metal Barbed Hose Fittings for Air and Water
Slide the barbed end into rubber hose and secure with a clamp or a crimp-on hose ferrule.
Brass fittings are softer than other metal fittings, so they’re easier to thread together. They have good corrosion resistance. Fittings with a threaded end are also known as hose nipples.
3D CAD models available
For technical drawings and 3-D models, click on a part number.
Straight Adapters, Hose × BSPT Male Threaded Pipe
  • Maximum Pressure: 250 psi @ 72° F
  • Maximum Vacuum: See table
  • Temperature Range: -40° to 160° F
  • Attachment Type: See table
  • Specifications Met: SAE J476
Brass
For
Hose ID
Pipe
Size
Max. VacuumAttachment TypePkg.
Qty.
Pkg.
Brass
For
Hose ID
Pipe
Size
Qty.
Pkg.
Good info, thank you!
@rkymtnflyfisher so Ryan it looks at though you want to cross a few creeks to scout Trout on the other side? Hard even finding water here in AZ so rerouting the breathers has not been high on my list. Having a gorgeous day here in AZ today, hope the skies are blue in Montana today as well👍
I'm not necessarily looking to ford any creeks, my biggest concern is all the gear lube that leaks out of the axle breather. I get tired of cleaning up oil from the rear axle, it leaks a whole lot more oil than my leaky ass transfer case!
Going to be rebuilding my TC, 4 speed and new clutch in December👍
Luckily a quick mud search shows this subject has been hashed out in the past by many people. There are super simple solutions to this.
Keep it simple.
  • 1911
