Check out the last post
https://forum.ih8mud.com/60-series-wagons/394565-tank-fuel-pump-conversion.html
The external pumps are really easy to service, which is something I loved about the setup. I had bad luck running them though, maybe I was running the wrong ones (walbro 225), or they were too big and tended to pull too much fuel and cavitate i'm not sure. Maybe the stock 5/16 hard line in the tank is too small, maybe mine was mounted too high..
The external setup does work, just make sure you carry an extra pump with you in case you have any problems. It saved me a few time. Lots of folks doing the vortec swaps in all kinda of vehicles use external pumps and do fine though. Make sure your prefilter for the pump flows a good amount of fuel to reduce the suction on the tank side... that was something I noticed made mine cavitate. I ran a cheap 3/8 barb plastic filter for a while and it worked OK, but you could see it pulling a vacuum inside. I tried a really big metal filter (just browsed napa for one) and it was really bad. The best luck I had was running a simple in line screen that flowed a lot a fuel.
something like this:
Summit Racing SUM-230101 - Summit Racing® Full Flow Fuel Filters - Overview - SummitRacing.com
Anywho, just trying to share what I learned, not saying you shouldn't do it.
cheers![]()
Staying external to facilitate in the field replacement....
I talked to Mountain Cruiser (Tony, very cool guy). He has a 5.3 setup in his 40. He mentioned using a pump off an isuzu npr (with 6.0l) He said its extenal in the stock configuration and works well, very reliable. I think I'll go this route...
I meant look at the very last post for filter and fittings part numbers.
Hey I got your pm I did talk to him but he said he can't get to anytime soon i'll ask him for a recommendation of someone else local.
I would reccomend posting in the az copper state cruiser forum for a local recommendation the Arizona club is pretty active and very helpful.
If you want spring over in the future now is the time. Your going to need some drive shaft modifications anyway so there's no sense spending the money twice. . I wouldn't recommend a cut and turn with a v8/auto swap. 1 its 100% unnecessary since by the time you swap your v8 your front drive shaft becomes much longer. 2 if your doing it to run a cv drive shaft don't!!! To run a cv drive-shaft in mine I actually had to modify not only the pan and the cv joint which was custom to begin with, I had to modify the internals of my transmission to gain the necessary clearance.
If done again I would run a u joint front drive shaft, with the added length the angles aren't much different than stock sua.
There will be lots of opinions from people who say otherwise but the fact is I drive 80-85 every time I hit the freeway and it is smooth as butter even without a steering stabilizer. It also tracks very straight. Have also been up arond 65-70 in 4wd without vibes.
When you install a v8 auto and adapter it changes things drastically so cnt debate from people with 2fs becomes irrelevant.
Seems I have a few options:
1. Stock 60 tank, cut up and add aftermarket setup like this FUEL PUMP ASSEMBLY FOR STEEL TANK
2. Stock 62 tank, swap appropriate fule pump. Manu, can you help here? This is what you did right?
3. Aftermarket tank and stock chevy fuel pump. Like rover67 did.
What do you guys think? Are external pumps that bad to NEED an in-tank setup?
Well, An inline pump and the vette filter is super easy to do. You can run that and get a feel for how it all works then maybe decide on going in tank if you wanted.
Here's a thread on the pumps:
https://forum.ih8mud.com/hardcore-corner/343545-external-inline-fuel-pump-recommendation.html
Yeah I ran a fj62 tank with a walbro pump in it.
It ran great from day one and never had any issues....
I ran it this way not cause the inline fuel pumps where "bad", but cause they were too damn loud for my liking... I could still hear the damn thing even with the radio blasting... so I went with the in tank set up.
With a V8 set up you'll find real soon that you'll be willing to use your truck a lot more often on long drives and a long range tank is the ticket.
Having fuel cans is cool as hell, but pouring them into the tank is another story........
I think with either of the 3 choices you got yah cant go wrong... lots of guys run inline fuel pumps without any issues and the same can be said about in tank fuel pumps..
I can get the part numbers for the walbro pump if you go that route....
the 62 tank is identical to the 60 tank. bolts right up.
The only difference is the 62 inlet for the fuel pick up is slightly different as it accommodates the fuel pump into the tank. the sender is the same as the 60.
