Aluminum cracked wheel
Discussion in '60-Series Wagons' started by jvazquez53, Feb 10, 2009.
  1. jvazquez53
    jvazquez53 El Tractor
    3,353
    Media:
    13
    Albums:
    2
    280
    May 6, 2007
    San Juan Puerto Rico
    When I crashed last week, I discovered that one of the aluminum wheels had a small crack in the inner lip, about 3/4 inch long. Can this crack be welded? Also the wheel is slightly bent which I'm not too concerned. Reason I like to keep these is the way they are designed, look at the valve stem, perfect for off-road.:hmm:
  2. sl33py
    sl33py
    2,160
    8
    Jan 8, 2004
    Emerald City
    maybe make that wheel your spare - if you can repair it?
  3. NocalFJ60
    NocalFJ60
    3,550
    Media:
    6
    Albums:
    1
    6
    Aug 2, 2004
    San Francisco Bay Area
    TIG welding is the best way to weld aluminum from what I have been told. It can be tricky if you don't weld a lot.
  4. LCOwner
    LCOwner
    901
    3
    Jun 23, 2002
    Madera, CA
    WHeels are repaired here in the states all the time. It's just a materh of finding someone to do it there.
  5. ntsqd
    ntsqd technerd
    5,472
    326
    Apr 26, 2007
    Upper So. CA
    Ideally it won't have a tire on it and that area around it will be clean. Down in the crack needs to be clean too.
    Were you anywhere close-by I could fix it. What I'd do is this: first grind out the crack, then heat the area around the crack up to maybe a couple hundred degrees. Then I use a stainless steel bristle brush (that has NEVER been used on steel!) to scrub off any oxidation. Weld it, then heat the area back up again, and let it cool in still air. Burying it in sand, at least the weld region, after welding isn't a bad plan either. You want it to cool as slowly as possible.
    If you have the tools to do so, V'ing it out is OK, but the wire brush scrub has to happen immediately before welding.
