Builds AK HJ-75 (5 Viewers)
Anybody know where mr T put these diesel stickers?
New seatbelts, but the end of the belt that bolts to the bottom of the B pillar has a different mounting😳 well, off to check the parts book again
Well, nothing is shown in the parts book🤷‍♂️ And when you look at the instructions diagram it shows a bolt there, but doesn’t show it as needing to be added. Anyone got any ideas?
When "ordering" this seat belt from a vendor it shows a separate bolt also, which looks like the right size to fit that empty hole.
At least I didn’t have to cut out the hole anymore.
Maybe put diesel label above filler to avoid drips.
About seat belts, I just remember reading that the bolt heads are a weird size to distinguish them from others. Maybe they are heat treated steel.
My feeble thoughts ..... I would put it where there is no chance the fuel nozzle or spilled fuel could possibly damage it.
So maybe put it above the cap rather than below, as seen in that image provided.
I zoomed in on the original photo that I took and, assuming you are talking about the beige one, I am not sure that's a Diesel sticker....maybe it is but it appears to be mounted vertically if it is.
This thread does raise a question. Both of my fuel caps have Arabic writing on them and are most likely aftermarket. I should possibly look into the locking version. (sorry for the hijack)
HZJ79
I just looked again. It does appear to be a Diesel sticker mounted horizontally but it also appears to only be half of one...."esel".
They all have English on them over here; at least all that I have seen, including mine.
