So, I found a set of 30-spline hubs for my 40. 10/77 date (1978 model) They were in good shape already so I cleaned them up, applied new grease after assembling them correctly. I put them on the 40 and did a quick check and they functioned properly. Free spool in free, and turns the driveshaft in lock. Perfect, right? Of course, I should realize nothing that I do in the garage ever goes smoothly.
I tighten the 6 bolts down and realize that everything is now locked up. WTH??? I cant turn the axle or the dial on the manual hub.
So, I pull everything back off and realize that the housing is too shallow with the split ring installed. It is literally 1/16" off. I pulled the split ring off, installed everything again and it all functions perfectly.
However, I know I need the split ring installed.
So, after doing some research, it appears that I may need a longer housing for these hubs. The reason I am confused is that in pictures, the two different housings are about 1" different and I literally only need about 1/16" clearance. I don't know why mine would be so close to working.
So, what are my best options to make these work?
A few options that I think are out there are as follows:
-Buy new housing and use the internal parts I already have.
-Buy different Birfields? but which ones?
-Is machining the groove for the split ring back slightly on a lathe an option? There is plenty of room on the shaft.
-Sell these to someone and buy aftermarket hubs, such as Warn ( I do not want to do this if possible)
Any suggestions is appreciated. As mentioned, I have done research but can't figure out what I would need to change, if anything to make what I have work. If I need to give measurements, I can later tonight.
