It has all been said in the above posts.
The video and “Cheat Sheet” provided by
@suprarx7nut are great places to start.
To add some more detail comments:
Sensor readings per screenshot at your Post #3:
negative 18.2 millimetres -- Front Right Sensor
positive 3.4 millimetres -- Front Left Sensor
negative 0.6 millimetres -- Rear Sensor
Difference Front Right and Left =
14.8 millimetres
Difference Front Right and Rear =
17.6 millimetres
Looking for Sensor readings close to
zero +/- 5 millimetres (+/- 0.2 inches).
Is this vehicle on a slope to the Right?
If yes, re-check Sensor readings on level ground,
If these ARE the Sensor readings taken on level ground (not in the street), then either
a. The vehicle has a lean, downwards to the Right (if so, correct by ‘cross-levelling’ the Front using torsion bar adjusters, not Height Control Sensor adjusters, engine OFF, equalising Right and Left hub-to-fender using a tape-measure),
or,
b. Height Control Sensors are out of adjustment (if so, correct to zero +/- 5 millimetres at
N height setting at preferred ‘ride height’ for the vehicle),
or,
c. One or more Height Control Sensors are faulty (if so, check using FSM method or similar. Attempting to repair/refurbish a faulty Sensor is a mug’s game -- suggest replace faulty Sensor(s) with new OEM Sensors, avoid troublesome cheap fakes and avoid pre-owned Sensors unless tested).
Wide differences in Sensor readings can lead to the Suspension Electronic Control Unit (ECU) initiating ‘fail safe function’ in which Active Height Control (AHC) and Toyota Electronic Modulated Suspension (TEMS) are prohibited.
Alternatively, the difference may result in erratic or strange height behaviour, such as you describe.
The good news is that on your vehicle, AHC is still working, proven by the Techstream readings you have obtained, so the ‘fail safe function’ has not been applied by the ECU. This may indicate that the internal condition of the Sensors is OK, and perhaps a ‘lean’ or ‘slope’ is the issue -- but suggest always remain suspicious of aged Height Control Sensors.
By the way, for reasons explained in other posts, absence of Height Control Sensor DTC's on Techstream
does not provide assurance that the Height Control Sensors and circuits are in good health. Inspection is insufficient, testing is necessary.
AHC pressure readings per screenshot at your Post #3:
12.4 Mpa -- Front AHC (FSM-specified range
6.4 MPa to 7.4 Mpa)
9.2 Mpa -- Rear AHC (FSM-specified range
5.6 Mpa to 6.7 Mpa )
10.8 Mpa -- Height Control Accumulator (commonly observed in the normal range
10.2 Mpa to 10.8 MPa) .
At these very high AHC Front and Rear pressures
- damping is severely compromised and ‘ride comfort’ is guaranteed to be rough and springy, and,
- if left in this condition, there is a high risk of challenging the seals in the ‘shock absorbers’ and elsewhere, resulting in leaks and possible permanent damage.
Best to adjust urgently, and change AHC Fluid as already suggested by others – but note that changing AHC Fluid will not by itself correct these over-pressures.
If the ‘globes’ in this 23 years old, 202,000 miles vehicle are original, then they are well past their best and it is highly likely that a requirement for set of four (4) new ‘globes’ is in your near future – subject to testing as mentioned below.
Poor ‘globe’ condition will not be revealed by Techstream.
AHC pressures are governed by weight share between the mechanical suspension and the AHC system. Overall 'globe condition' has nothing to do with AHC pressures.
‘Globes’ in poor condition prevent effective damping and will result in very poor ‘ride comfort’.
If not seen before, definitely suggest also peruse this thread:
The ABCs of AHC - How to Measure, Flush, and Adjust all in one place - https://forum.ih8mud.com/threads/the-abcs-of-ahc-how-to-measure-flush-and-adjust-all-in-one-place.1211999/#post-13116520
In summary, the correct sequence for AHC adjustment and ‘tuning’ is always the same order:
1. Check that vehicle vehicle is on level ground, wheels straight ahead, fuel full, no poorly distributed loads,
2. Check condition of Height Control Sensors – all should be close to zero +/- 5 millimetres or +/- 0.2 inches (AHC system cannot work correctly with faulty or incorrectly adjusted Height Control Sensors – absence of a DTC does not provide assurance of healthy Sensors),
3. Check/adjust/equalise Front ‘cross-level’ with torsion bar adjusters -- measured by tape-measure, engine and AHC “OFF”, then,
4. Check ‘ride heights’ at
N height, measuring hub-to-fender by tape-measure – engine “OFF”, ignition “ON”, adjust if necessary using adjustment procedure and Height Sensor Control adjusters (not torsion bar adjusters), then,
5. Check AHC pressures by Techstream at
N height after
N > LO > N movement (allow 30 seconds after green AHC dashboard light stops blinking after arriving at
N), then record Techstream results for Front, Rear, Height Control Accumulator, then,
6. If AHC pressures are out of the FSM-specified ranges, then (i) use Front torsion bar adjusters to vary share of Front vehicle weight carried by torsion bars and share of Front vehicle weight carried by Front AHC system, thereby adjusting Front AHC pressures, and, (ii) consider spacers or replacement/upgrade of Rear coil springs to vary share of Rear vehicle weight carried by springs and share of Rear vehicle weight carried by Rear AHC system, thereby adjusting Rear AHC pressures. (Note: Front AHC and Rear AHC are not hydraulically connected but changing the Front and Rear weight distributions may cause some small interactions between Front and Rear AHC pressures and some ‘fine tuning’ may be required), then,
7. When heights and
AHC Front AHC and Rear AHC pressures are correct, check overall ‘globe’ condition by observing the
difference in AHC Fluid level at AHC Tank between
H and
LO heights. Per FSM, difference of around 14 graduations means ‘globes’ are near new; when the difference has declined to around 7 graduations, replace all four (4) ‘globes’. Results of this test at incorrect AHC pressures are not comparable with FSM numbers.
