AHC problem Hdj 100
sweden
Hi !
I have a 2003 hdj100 with rear suspension problem .
It droped in the rear .so to start troubleshooting I took of the arm to they rear hight control and work It manually ,it will fully lift and lower but nothing in between.
I changed the rear sensor with the same result when the arm is in drive position it will drop
The front works as it should
Any ideas ?
Do you have techstream? You'll want to read those values to help guide you on this. With Techstream this sort of thing is quick and easy. Without Techstream it'll be a game of guess and check.
Thanks for the response! I don’t have techstream .I’m searching on the web but unsure what to download
Any links ?
