Along with what all the other members are telling you to check, I'd also check out the condenser core. When i did the cooling system on my truck, what i found was after 22 years of use my trucks condenser was plugged full of bugs, leaves, and other crap. I spent a few hours using a small nylon wire tie to clean between the fins to remove all that crap. So first off, you need to check to make sure that you don't have any bent fins, if you do they can be combed out. Next, look to make sure that your core is not plugged with bugs, leaves and other crap, if it is you'll need to clean it. If the core has any oil on it, you need to clean that off too, because oil attracts dirt, and dirt will plug your core. Last, you can pick up a can of spray foam cleaner from an AC shop, use it to wash the condenser to finish your project. As a plus from doing all this work, you'll now be getting alot more air flowing through your radiator, and with these trucks, they can use all the cooling help they can get.
