Yes, divine intervention. Twice: 1) unsolicited refund and 2) guardian angel disguised as 3 y.o. However, be aware, the 3 y.o. will eventually become a teen... You will pay it all back then, brace yourself....!
Million Dollar Build...haha. I see it much more as a Delayed Gratification Build.Goodness gracious! This is a million dollar build. Respect for doing all of your work yourself!
How hard was it to remove the rear AHC lines and the top bolt for the shocks? Did you choose to drill a hole in floor from the top or just managed it from the bottom?
Well, guess what showed up in the mail todayI tried to plan ahead and order a 12mm flex head wrench, but it is still missing in the postal system two months later.
Maybe if I flipped them over you would think differently? The factory arms are stamped steel and the Dobinson arms are "Made from HSLA (High Strength Low Alloy) Steel, 5mm (0.2″) wall thickness" tubing. But strength isn't actually why I was interested in them. Heck, I didn't even need the built-in caster. I needed the upper control arm to stop beating up my AHC shock during down travel.
Thankfully, they fit the bill perfectly!
Do you have a list of part numbers for this? I want to do the same, but it seems I may need to relocate power steering reservoir and maybe other stuff?But First...A Cyclonic Air Filter
It returns to the original limiting factor, which is the extension capability of the AHC shock.Question for you, with the new Dobinsons UCA what becomes the limiting factor in down travel since it no longer is the interference between the shock and the UCA?
Pasted from my Partsouq order:Do you have a list of part numbers for this? I want to do the same, but it seems I may need to relocate power steering reservoir and maybe other stuff?
# | Number | Name | Make | Qty | Qty Supplied | Price |
1 | 1770050182 | CLEANER ASSY, AIR | Toyota | 1 | 1 | 453.16$ |
2 | 1787550280 | PIPE, INTAKE AIR CONNECTOR | Toyota | 1 | 1 | 206.42$ |
Thanks! I though maybe I’d need different PS lines and reservoir bracketPasted from my Partsouq order:
# Number Name Make Qty Qty Supplied Price 1 1770050182 CLEANER ASSY, AIR Toyota 1 1 453.16$ 2 1787550280 PIPE, INTAKE AIR CONNECTOR Toyota 1 1 206.42$
Made a plan yesterday to relocate the PS reservoir, will execute today and post some pics later.
