ACE tintable Rustoleum product (2 Viewers)
Nice work!! Did you paint the rims and if so do you have the color code for it???
Great Job!! I just did a trailer with Rustoleum silver..you think that could be clear coated too? I know you had a lot of hand work..but I was just hoping to perserve the silver a bit. I still can't believe how good it looks for ACE paint..they ought to put on a commercial:)
Spray gun for Ace paint?
I need a gun to shoot a fender apron and misc. touch up. Should I just get a lower-end touchup gun someplace like Sears, etc., or invest in something of higher quality? Plan to get an economical compressor - minimum size.
This stuff (Ace paint) does seems to take longer than Rustoleum to dry, but could that mean the final finish a bit tougher overall? Color match is great, just took a long time to find a guy (at Ace) who understood what I was after and knew what to do with the machine. I held up a fender apron and he took the measurement. :D
Just buy one rattle can to match from towerpaint.com save you a ton of time and $$$$.
Many Napa auto parts and also some Sherwin Williams centers will mix rattlers as well. Call around if one can isn't enough. They usually go a long way though. Good luck!
I don't know about everyone else's but my ACE just told me that they are discontinuing their version of rustoleum. But i did but a gallon of paint for my troopy and my mower. Figure try painting the mower first, then the troopy (since i have a month or more till it gets here)
As for painting equipment, Harbor Freight is a great place for compressors and paint guns. You can get a nice setup for under $200, and you can order it online and have it shipped to you.:cheers:
CrazyGreek - Your paint job looks awesome. How much of the Ace paint did you wind up using? It looks like you covered everything in what three coats?
Thanks
Thanks
Hello,
thx
I used 1.5 gallons and 4 coats in places, 3 in others.
:cheers:
help matching rim color
I have set of stock steelies that are black. Want to change to factory gray. Does anyone have the code to match ? I don't have anything to take in and have scan'ed.
Thx
Thx
I picked up some Valspar Tractor and Implement enamal in Massy Ferguson gray from Tractor Supply. I just smeared a little on my wheel and it's a pretty close match, just a tad darker, it may change once it dries. I also got some of the Valspar hardener to try with the Ace paint, hopefully it will make it a little tougher.
Got the fenders flattened out..
First pic shows the slight dip in fender, then abracadabra, poof it''s gone.. Straight as can be... plus some dust...
What's a good way to start with body hammers/dollies? Looks like the Martin stuff is good? Snap-on seems way expensive (and looks like it's made by Martin anyway)?
The code for the ACE Rust Stop Paint for OLIVE 653 is
Ingredient | Formula
AXX | 0 18 1
C | 0 25 0
L | 2 16 1
This is how it appears on the side of the can. And no they do not use Auto color codes. I used a color chip and they used the laser spectrometer and created the paint. The color is DEAD ON tho. I sprayed it on next to a area that I shot with Automotive paint at $50.00 a quart using the 653 code. After drying I could not see any color variation. Amazing. And this stuff does not run. Very high solids. I will be shooting clear over it as well.
When I stopped at ACE 5 people were taking a look. One guy took a couple pics... (wow, is this normal?) Picked up a couple bolts n such, then drover her home.
My 62 is in Yota color 155 (it seems that 75%+ are...). Given that I do not want to disassemble the vehicle down to the body, I am going to stcik with this color. Otherwise, that olive is fantastic!
Anybody got an ACE paint formula for the 155 like the one above for the olive? I assume they can dial in the ACE formula without using the laser thingy... I guess I could always remove the fuel door... I'm also considering having Durabak custom make me 5 gallons matched to 155 and going that route, at least for the inside.
I'm going to my ace store today. I called and they said they can scan in my color so its off to buy my paint. :D I will post updates as I get them. I hope mine turns out as well as some of the others.
Reading this thread I saw this post from about 9 months ago. Does Ace still sell this paint?
Also, any chance Greek can post a pictue of his Breathe Green 40? I've been looking all over for a picture of a Cruiser painted that color!
ACE Paint
ACE Still carries this line of paint. I had a small batch of 653 OLIVE made up about a month ago.
As far as the Breath Green sample. Well, I am going to paint my rig that color (maybe) but you are in the same boat as me. I have never seen a Breathe Green sample. (at least one that the owner KNOWS its breathe Green)
I have ssen some green rigs on MUD that I think are Breathe but not sure 100%
Let me know when you see one... :)
These are close
Where has people found the valspar hardener? Lowes or somewhere else? I stopped by the local Ace and they still have it, you can shot their primer over any high build product or bondo then paint it. I oredred my paint today and will be here by Wednesday.
So the only way to get a particular color at ACE is to bring in the color needed or wanted. They will then produce a gallon of the color matched paint? Where does one go to find a sample of something like the green 40 posted above?
Would really like to try this inexpensive way to paint my cruiser
Thanks
DEL
Thanks
DEL
Del:
The 40 pictured in the earlier post is painted in 6h9 "greyish olive." If you would like I could mail you a spray-out sample for color matching; just send me a PM with your mailing address.
The only catch is that you have to post the mixing formula once Ace gives it to you!
