Hey all- after a ~8 year time period away from Toyota 4x4s (well, all 4x4s, sadly) I recently picked up a 94 4Runner with the 3VZE and A340H trans/transfer. I got it at a very good price with low (for the year) miles mainly because the transmission, while completely functional, had a nice crack in the case the leaked fluid like crazy. I got a used trans/transfer with fewer miles and did the swap.
Everything is in, but regardless of how I adjust the transfer linkage it will not come out of 4Lo. If I disconnect the linkage and manually move the lever to 4H or 2H it still is in 4Lo. I don't think the ADD system disconnects as it does not like sharp turns on pavement.
So here's what I think are possible causes:
If you have some deeper experience with this transmission and have a little insight, I'd sure appreciate your help. Thanks!
- Bad connection (I did wrestle with the two 6-pin connectors above the bellhousing when removing the old trans)
- Bad switch or relay
- Bad or not-connected solenoid
- Hydraulic issue in the transfer
- Mechanical issue with the planetary gears, clutch, or brake in the transfer
