- Joined
- Feb 10, 2002
- Threads
- 550
- Messages
- 44,830
- Location
- Canton, Mississippi
- Website
- www.seeandeatms.com
Love it
Hmmm. Maybe timing or carb adjustments?It wouldn’t idle that good with a big vacuum leak!
I removed one nut on each side of the rails. I was able to pry upwards slightly and pivot each out of the way…I think the rail should slide out of the way to expose the nut
@wngrog Let’s go back over three and a half years ago…. I trust my SOR kit is designed with springs in mind, yes. Guess I could put another section of foam in there and eliminate springs? Mine have surface crust but are solid…My local upholstery guy replaces the springs with full foam cores.
Sweet. It’s settled then. I’ll hopefully post photos when I get it knocked out.Daniel, I did the sor foam and original springs a while back, and was real happy with the results.
