kcisland
eaj71,
I am having the exact same problem and may have the answer. Measure from the bottom of the tang to the first seat on the bottom of the helical gear and see if they are the same. Look down the shaft and you will see a seat that this helical gear hits. I believe mine is hitting this seat before engaging the tang in the slot.
Here put a screwdriver on the seat above the slot and put tape to mark the top of the block seat.
When I touch the tape to the helical gear you can see where the screwdriver tip ends is the same spot that shows sticking above the block.
When I put the screwdriver into the slot and mark with tape to the top of the block, then go back to my new dizzy and put the first mark on the helical gear, it shows how much the tang will miss the slot.
Check yours and see if you find the same issue. Mark, what do you think? Am I way off here?
Keith
Keith
