Dear Fzj80/Fj80 Experts,
My 1997 has an AC problem.
Every morning it starts cooling perfectly.
Then after 30, or 45 min sometimes a bit more it all of a sudden stops cooling.
I've used a code reader to read real time engine temp and it nerver goes above 195- 197F . Read that the AC cut off relay is activated at 220F.
The AC clutch engages perfectly as I see its effect on engine RPM if I turn the AC on or off.
So far I do not understand where is the issue. Could it be a Frozen Evap? Or AC amplifier or AC system amplifier?
I read the FSM trouble shooting. Checked the little visor next to the battery. As per instructions. When AC is turned off threre should be bubbles and they should then dissappear. When the AC stops working. I trun the AC off and there is no bubbles.
Any suggestions?
Thanks!
Hernan
Any suggestions?
Thanks!
Hernan
