Alright so my 1992 fj80 3fe 111,000 original miles is overheating and trying to figure out what it is and need some opinions...
First off Radiator is less then a year old, Has new shroud, fan clutch (green), water pump is maybe 1.5yr old bought from rock auto (aisin), coolant has been flushed but a little concerned (checked reservoir today and found black flakes all in it) thermostat is 3 months old (190deg), new 13psi radiator cap (tried a couple different ones no difference.)
New spark plugs, timing slightly advanced but made no difference when retarding it slightly per FSM, compression good and valves adjusted to spec. checked coolant for combustion gases all good, system has been burped of air.
So it seems like every few months the cruiser will start to overheat last time I swapped out thermostat and it worked fine for a few months now doing same thing again and is kinda frustrating. So today I sat in drive way put ac on high and held rpms at 2500 to get it to overheat took about 15-20 minutes while taking temps at various areas verifying it actually is overheating. the fan clutch seems to be working speeding up and slowing down with temp. with radiator cap off it doesnt seem like there is much movement when thermostat is supposed to be open but hard to tell.
these are the temps that i recorded
Top area of thermostat - 200deg would of got higher but didnt allow it to. BTW will idle all day long without overheating.. only overheats under load
water pump housing - 130-160 f
upper radiator hose - 190-200 f
lower radiator hose - 150-165 f
From looking at those temps it seems to me that the thermostat is not opening again... What are your thoughts?
Ive attached a pic for reference of where i was taking measurements highlighted temp with highlighted area on engine if that makes sense. thanks in advance. Mike
