Yeah, I have one or two. As for torquing down the bolt, just go buy a harbor freight earthquake impact wrench.
Or a HF 300ftlb torque wrench. I used it and it was fine. Did the deep socket on the flywheel. Not ideal but it worked.
I think you could make the same tool without welding anything. Get a Big piece of angle iron cut the holes as we did and go with it. As long as you have a place to fit the socket in to the crank pulley you should be good.I don't have a welder so when I did mine I just went and bought some flat stock as wide as they had to occomodate a big hole centered in the stock towards one end large enough for the socket to fit though it. Marked and drilled the 2 smaller holes for the bolts. It took a couple of minutes to make but worked well enough. Something like the one above is probably a little stronger but if you don't have a welder you can still make something that works.
OK! Made the tool out of angle iron and it fits in just fine. Went to A-zone and they only had 250lb T-wrench. Disgusted. Then
I thought about a locally franchised CARQUEST and they have a 500lb wrench but too late to get there. Will try again Thursday.
On hb bolt popped right with I/2" impact and hp came right with minimal effort.
OK: torqued th balancer to 305 lbs. Still no power steering. The engine sounded rough at first but then quites down and sounded pretty good with good oil pressure but when you put it in gear and drive it there is a knock that to me does not sound like a rod but it there is a knock.OK What happened? Why are you selling it? You state it has a bad engine. What did you find?
Conclusion: Jus to complicated for me. I am 86. Not excited enough about it to continue. Let someone with more enthusiasm have a go at it.
found an engine and trans-tcase from a 97. Any reason this will not work in a 93
