93 Fzj80 turn signal flasher relay?
Was this an issue before needing to replace the relay? Sounds like there's some interesting wiring somewhere behind that dash.
When you say the clock flashes, does the display dim or shut off?
I haven’t noticed any dimming on the display. I have done nothing electrical on the truck for a long time. So I don’t know what triggered this problem? I’ll check my grounds tomorrow if I can find them. My cruise control has tended to switch off when flipping the turn signals for a couple of years. Could this be my signal switch? Btw. Thank you for the response
My dash lights along with my clock blinks when right turn signaling. Left turn is signaling normally. New bulbs. Two different new flasher relays. New fuses? What am I missing? I appreciate all your help.
Any chance you could get a short video, would help to see exactly which lights are blinking with the indicators.
Check the ground point behind the drivers side kick panel.
Have a look at the tail lights while the indicator is on, all acting normal? Try removing your pass. side tail light, remove all bulbs, see if that resolves anything.
Finally got some help and figured it out. Some damage to some wires above the spare tire area. Looks like I need a new rear taillight wiring harness. It’s patched and working now. I truly appreciate all of your support and responses. Thank you.
this is bad news
I made a mistake, the NOVITA EP36 does work.
Here is where I went wrong. The factory flasher was mounted with a jumper. I incorrectly assumed the NOVITA would need that as well. Instead, you discard the jumper and its mount and install the new relay directly into the panel. My apologies.
What a great thread!! Fixed me fast right side blinker with the EP36 because I do have a ARB bumper and a few LED's.
Thank You!!
