Has anyone used a shiftworks shift cable for the a their trans shifting? They look super clean, they are shorter than the trailblazer cable (which i have already). I called them, they are unsure if it will work because they design them for their shifters in mind. They dont know if the toyota shifter and the 4l80 lever match in their distances and stuff like that. I am unsure if I have it correctly in my mind. I measure the distance from park to low on the trans and the distance from park to low on the toyota shifter and i take the greater of the 2 for my throw distance...?
Then i measure the degrees between each gear on both of them and match them up? or is that where the modding begins? and does this have to be done with the trailblazer cable? I know that the cable end doesnt necessarily mount to the toyota shifter directly there will be slight modification there or adding a heim to something etc. but unsure about the cutting of the arm to get the degrees to match? this is where i am unsure...
@thatcabledude you have been invaluable on this topic i have looked at your photos but i just am not clear on this last part. (edited since original posting)
