I have been at wit's end trying to chase a mysterious coolant consumption issue.
Several months ago I noticed my reservoir tank had been at the minimal mark, I assume staying at a level that the pickup can no longer take in radiator fluid. I filled it up with Toyota Red 50/50 and thought nothing more of it. Fast forward to a few months later (I drive around every few weeks or so, my rig only coming out for special weekends or camping trips), and I noticed the level back down at the minimal mark. I had probably put about 500-800 miles on the truck before popping the hood again and checking. Filled it up again.
I got alerted to this because on my last time offroading, I luckily noticed my temp gauge creep quickly up to HOT (230-240*F) and then fall back down slowly. It never got towards the hot mark again. Later that weekend, got under the truck, and noticed the lower hose from the water pump had some dried red coolant on one of the clamps. I assumed a leaky water pump and trying to confirm my suspicion, I drove the truck around more frequently and at freeway speeds (+30 min drive times) to ensure I was fully up to temperature. I am not seeing any new moisture on the lower hose or clamp area, and no other areas have dried coolant. The reservoir dropped another 1cm off the max line.
Things I've done:
1. Pressure tested the cooling system with a rental tool up to 15 psi. I followed the instructions and did it while the car was cold. No leaks found after holding pressure for about 15 minutes. The kit did not have the right fitting for my cap to test, but since the overflow tank is receiving coolant when the car is warm, I can assume(?) the cap is working properly.
2. Ran the rear heaters during the diagnostic and "driving aroung" stage. No coolant found on interior of the truck (none that I can find), and no coolant on the lines going to the rear heater.
3. No coolant weepage when the car is hot from the breather tube on the overflow tank.
4. Checked the dipstick for coolant or watery looking oil. Nothing that I can find, but I am planning to do an oil change this weekend and a blackstone analysis to rule that out.
5. Condition of the upper and lower hoses seem to be in good shape.
6. According to the PO, water pump, thermostat, radiator all replaced 8 years ago (about 20k miles ago)
Any ideas on things to look for? I am about to throw it at a shop and have them pull everything off to sort this truck out, but if I can avoid spending $1200~ to do that, then I would much prefer to play out all my options.
Things I've done:
