Good Morning Gentlemen, I was referred here from the Pirate4x4 forums, hope someone has some insight here:
So, I've been working on a client's Land Cruiser for a little while now. The engine has received quite a bit of attention over the past year because it was neglected for a while. Its been overheating frequently, and dumping coolant after shutdown from what appeared to be the water pump. Also, multiple times after overheating it would release steam like a kettle from where the water pump meets the block. After doing some inspections, I found many of the smaller coolant hard lines completely plugged from corrosion. Thermostat tests fine in boiling water. Fan Clutch is fine. Water pump is new.
So my master plan to fix their overheating once and for all was to replace the now compromised water pump gaskets, replace thermostat gaskets, run a few strong coolant flushes (with cleaner), replace the plugged lines, replace radiator cap, replace WP bolts, and refill with proper distilled water/glycol mix.
BUT after a week doing all of this work the bastard car is once again dumping coolant after shutdown
. If pressure is building up in the cooling system I can't understand why it is pushing its way out the water pump instead of the pressure cap on the radiator!
I need some brainstorming help here guys. Is there something about the way coolant circulates through this block that makes it prone to building pressure in the block? I cant for the life of me find a diagram highlighting how coolant circulates through this engine even looking through the FSM.
_________________
_________________
