82 fj60, water pump air pump belt, can't fit the new on one. (1 Viewer)
caladin
Noob, but trying to learn
Pflugerville Tx
Website
bz93.com
I bought a complete set of new ac delco belts from rockauto, but i cant' get the air pump/water pump/crank one on.
It's a T22434/88933259 belt, i have the air pump loose at bottom bolt and tensioner is rattling loose. Even prying on it gently it's at a full stop
no more room to move, but i cant' see what it's hitting.
Is there some trick to it, the old one came off with just a tiny bit of prying. But i just cant' get this back on, I had thought this would be the easy bit...
Thanks,
Eric-
could you remove the pinch bolt on the tensioner, that should give the air pump more room to go towards the engine. once belt is on move pump and re-install bolt, then tension it
likr this set of real time photos , with a updated Belt tensioner installed also your needes parts diagram to :
HERE is The LINK with MORE TECHn and information :
My bando belt was the same. I ended up stretching it with ratchet straps to my patio supports over night. Worked fine. 😂 ideal? No. But I like to party.
