Thanks for the help Lou, these are the factory black finish that comes with silver faux bead lock rings on the 2012-13 Toyotas that have the Trail Teams package. They are not 17s as someone posted earlier. They are 16 by 7.5 inches and they are low pressure cast alloy that has a higher strength than stock. The bolt pattern is 6x139.7,the hub bore is 106 mm, the offset is 10mm. They won't fit without 2 inch spacers or machining of the hub bore where the hub cap lip interferes with our longer hubs. Both Luke and I went hub cap free.
Howdy! Are these DOT rated like most of the Toyota factory rims? Are they the ones that say they are made in China? I have seen several styles that are made there, but they are rated as Car wheels, not Truck wheels, whatever that means. JohnThanks for the help Lou, these are the factory black finish that comes with silver faux bead lock rings on the 2012-13 Toyotas that have the Trail Teams package. They are not 17s as someone posted earlier. They are 16 by 7.5 inches and they are low pressure cast alloy that has a higher strength than stock. The bolt pattern is 6x139.7,the hub bore is 106 mm, the offset is 10mm. They won't fit without 2 inch spacers or machining of the hub bore where the hub cap lip interferes with our longer hubs. Both Luke and I went hub cap free.
