Ha, can't tell you. I'm looking at headlights, mfr tells me they won't work out of the box if the vehicle has a passive grounding system, and points me to a shop that makes an adapter that mimics a standard ground for the headlight connections, if it turns out I need that. I can go back and ask what he means by "passive ground"--and hope he's not just repeating what someone else told him. Lemme do that...What do you mean by "passive ground"?
Only the high beams are a switched ground. The low beams are switched +12.Maybe he is referring to the switching concept. Typically lights and such like are energized by applying +ve voltage however Toyota energizes the headlamps on the 80 by switching on the -ve (earth). So if you tap off the headlight harness to activate the switch side of a relay then you get nada because you just applied a ground. A little fangling will sort it but its a pain in the arse if you don't know this beforehand.
Electronics (obviously) not my strong point. Do these rigs have a passive grounding system? ('95 here) I ask because something has to be modified if so...
To my knowledge, the product is beyond reproach. Staff is very helpful. How knowledgeable they are on this issue, I dunno...As long as their LED lights have a positive and ground wire coming out and the body/mount of the LED light is not electrically connected to either the positive or ground then they can be made to work.
Passive ground - if the manufacturer of the light (versus importer) states that, then I'd be questioning their engineering competence or congratulating them on creating a new bogus term
cheers,
george.
I was just looking at this. The lights you mentioned replace sealed beam lamps, like those on an FJ62. There's no way these will work on a US spec 80 Series. Look at the pictures on their web site. No gonna fit.Okay, now they're just pissing me off. Now they say ignore the "passive ground" thing (doesn't apply to 80s); the 80 series has composite headlights with replaceable bulbs--which somehow means that their headlights (which are designed to replace sealed-beam headlights) will not work in these vehicles. I'm gonna say that's gotta be wrong; if you wire them in properly (whatever mods that may entail), they're gonna work. Do 40s have replaceable-bulb headlights? Because I've seen these lights on those... Anyone? ...Bueller?
If you mean because they're round, @kelly saad ( landcruisergrilles.com ) has a very nice 7" round conversion housing (and various grilles to match). Electrically, it can't be that big a deal--or am I missing something (which is entirely possible)? Are you saying the sealed-beam design is too deep, or...? All I know is ICON runs these on their 40s, and they seem pretty awesome.I was just looking at this. The lights you mentioned replace sealed beam lamps, like those on an FJ62. There's no way these will work on a US spec 80 Series. Look at the pictures on their web site. No gonna fit.
No, I mean because a US spec 80 Series doesn't have sealed beam lights. You would need to replace the headlamp assemblies, surrounds, and other bits and pieces to Aussie spec. They got 4 sealed beams, the US market did not.If you mean because they're round, @kelly saad ( landcruisergrilles.com ) has a very nice 7" round conversion housing (and various grilles to match). Electrically, it can't be that big a deal--or am I missing something (which is entirely possible)? Are you saying the sealed-beam design is too deep, or...? All I know is ICON runs these on their 40s, and they seem pretty awesome.![]()
If you replace the term "passive ground" with the term "common ground" it starts to make sense.Okay, now they're just pissing me off. Now they say ignore the "passive ground" thing (doesn't apply to 80s); the 80 series has composite headlights with replaceable bulbs--which somehow means that their headlights (which are designed to replace sealed-beam headlights) will not work in these vehicles. I'm gonna say that's gotta be wrong; if you wire them in properly (whatever mods that may entail), they're gonna work. Do 40s have replaceable-bulb headlights? Because I've seen these lights on those... Anyone? ...Bueller?
Uh-oh. Now I'm thinking Aussie enclosures and--four of these headlights? Gonna hafta rob a bank or something... But about those bits-and-pieces--in addition to Kelly's surrounds? Dunno much about the wiring side of things. Or swapping out square lights for sealed-beam rounds...No, I mean because a US spec 80 Series doesn't have sealed beam lights. You would need to replace the headlamp assemblies, surrounds, and other bits and pieces to Aussie spec. They got 4 sealed beams, the US market did not.
Wiring LEDs shouldn't be an issue as long as each lamp has separate grounds for low and high.
I just visited landcruiasergrilles.com and now I see what you mean. That looks like it will take care of the physical installation.Uh-oh. Now I'm thinking Aussie enclosures and--four of these headlights? Gonna hafta rob a bank or something... But about those bits-and-pieces--in addition to Kelly's surrounds? Dunno much about the wiring side of things. Or swapping out square lights for sealed-beam rounds...![]()
