Keep in mind that you are choosing caster here, but on an AWD vehicle, caster has to follow pinion angle or you are likely to get driveline vibrations. The 80 series is unique in that the front driveshaft is OEM configured in a ‘broken back’ alignment, which means the pinion is pointing upwards more than would be typical. The beauty of this is that you can convert to a double cardan driveshaft, and without doing anything else, you have to lower the pinion to create axle end u-joint alignment. Lowering the pinion increases caster, which of course is why lifting without other modifications decreases it.
If you just pick caster, and you leave the stock driveshaft configuration, you are unlikely to have good driveshaft angles in terms of avoiding vibration at higher speeds. The stock setup has people reporting various results that in the world of how u-joint angles operate makes little sense (should vibrate, reported to be fine) but leading with caster when alignment is from the pinion angle is a crap shoot.
Landtank’s plates are unique in that they don’t just drop the bracket, but install in alignment to the factory brackets while drilling new holes. They are difficult to install due to tight spaces using a right hand drill but are a great solution. I am going to drop some massive controversy on your thread and show how I am using stock radius arms with Landtank plates and a DC driveshaft with proper angles and fit 38” tires up front without trimming the fenders or restricting up travel. I have no idea what my caster numbers are because they don’t matter - if I misalign my driveshaft it vibrates, to the point that I run one OME bushing upside down to get it properly aligned. Pics tell the story.
This is my original set beside the higher caster set after grinding/prying off the welds. You are drilling through those pilot holes, not just dropping the brackets like typical caster brackets.
You should weld them, easy enough to get back off if you ever should want to.
This is how the radius arms align. For anybody who plans to keep radius arms and wheel hard, notice how on 5.5” of lift the arms are basically flat under the angle and will act as a slider - this is an ideal setup vs a large bend to drop a radius arm under the tierod. Which brings us to tierod clearance - I have a larger diameter heavy duty Slee tierod and everything clears to pinion and arms without any grinding of the arms. Notice the pinion angle alignment for a double cardan driveshaft (no u-joint angle at the pinion).
