$80/liter transfer case oil (3 Viewers)
I went to my dealer today. $156 per liter for the Toyota 75w.
I ordered 2 L of Revenol 75W for $101 total, which included $60 in shipping.
I had some of the hex drain/fill plugs from when I had my 80 series. Will those work with the 200 for the diff and TC drain?
Note: I do not condone purchasing from this link. Search Mud for details.
Double check the overall length before running into the transfer case, but yes they’ll fit the rear diff, xfer, and front diff fill.
Front drain is a different thing entirely and if you don’t know about it search for the Lexus IS drain plug threads.
I have a pair of 80 lower arms you can have.
Did the rear diff and kept the original in the drain bc the magnet was about 1/2” longer. I replaced the rear diff fill with the hex as the original had signs of potential rounding. Better safe than sorry. Torqued both to 36 ft lbs. Weird that I drained about 3.75 and ended putting in around 4.2-ish. It wasn’t draining like crazy out of the fill, just a tad. All seemed well.
I’ll do the front and TC this weekend. I have Redline for the TC. Valvoline for the diffs.
I found this info on another thread a few months ago when I was putting together the parts list of what drain and fill plugs I needed to have magnets on all of the drain and fill ports for the diffs and transfer case. Also the list of the specific washers that are needed on all the ports.
Washers:
Front Diff:
Drain: 90430-24003 (flat copper washer)
Fill: 12157-10010 (crush washer)
Transfer Case:
Drain: 90430-A0003 (flat aluminum washers)
Fill: 90430-A0003 (flat aluminum washers)
Rear Diff:
Drain: 12157-10010 (crush washer)
All Magnetic Plugs:
Front Diff:
Fill - 90341-18035
Drain - 90341-24016 (Lexus only part)
Transfer Case:
Fill - 90341-18035
Drain - 90341-18021 (Have to use this flush mounted magnet version here)
Rear Diff:
Fill - 90341-18021
Drain - 90341-18035
