Thank you!i dont think so, they are pretty distinctive, will ck
side vents as in fender, or fresh air inside?Headlight trim, side vents, windshield and cargo window trim; basically anything chrome that I can get to play with while still keeping my pig together. Rear vents and lights if they are still in good shape; hard to tell from these photos.
fenderside vents as in fender, or fresh air inside?
3"-4" long black cylinder with wires attached mounted on the front side of the heater blower assembly under the hood on the passenger side. I'll get a pic tomorrow when I pick up my Pig at the body shop.your going to have to give me some help with that, where is it?, and what does it look like?
so Half wacked came out and half wacked away on this beast, he says the resister is in blower motor assembly- will have to remove to get to3"-4" long black cylinder with wires attached mounted on the front side of the heater blower assembly under the hood on the passenger side. I'll get a pic tomorrow when I pick up my Pig at the body shop.
Mine is from a ‘73 and is on the outside of the blower assembly. Must be different early vs late.so Half wacked came out and half wacked away on this beast, he says the resister is in blower motor assembly- will have to remove to get to
So I think that is we’re mine is, is it that spring thing with wires on it inside by blower motor I could be wrong mine was shot, have to pull heater motor out to get to it,so Half wacked came out and half wacked away on this beast, he says the resister is in blower motor assembly- will have to remove to get to
Just look at it it is behind the blower motor outside two phillip screws hard to get to good luckSo I think that is we’re mine is, is it that spring thing with wires on it inside by blower motor I could be wrong mine was shot, have to pull heater motor out to get to it,
And thanks SteveJust look at it it is behind the blower motor outside two phillip screws hard to get to good luck
DonAnd thanks Steve
