69 fj40 wonderbread thread (4 Viewers)
So this arm isn't spring less currently on the toyota and please exposing to me how this helps death wobble
Are you planning on wrapping that big U-bend exhaust under the hood? That will be a lot of area to radiate heat so I hope you're planning to wrap it.
Wasn't planning on it but its a good idea ill put it on my list of importance some where down the line.
nice build. are you going to build some sort of tray or something for the rear
Still got death wobble after ram install not as bad but the wheel wobbles I thing its the bearings
What are caster and toe set to?
Toe is zeroed out no in or out caster is fine. I pushed and pulled on the tire and watched in the inside my rotor disc moving slightly
are u gonna try a set of the springless steering arms, they are the only way to set kingpin preload with big tires
More than likely do u know what the prepossessing pressure is supposed to be
More than likely do u know what the preload pressure is supposed to be
More than likely do u know what the preload pressure is supposed to be. On a side note got my dash cluster panel from trailcandy.com took a while to ship beacause of holidays but its finnaly here
I tried the washer trickput 1/4 of washers on top of my springs on my kingpins and it didn't seem to do any thing I'm not getting death wobble since I put my ram on last weekend but its just making the problem I look out the window and can see my tire wobble and it gets worse with speed I can't quite afford. The springless arms. Right now. But even still I'm starting to think its my wheelbearings loose
What the heck?
I just saw this on ebay!? You've done a great job on it. Do you still have the death wobble?
