Been trying to get my 64 FJ45 on the road the past week and installed a new clutch master cylinder and new clutch slave cylinder. The truck has a 287 engine with a new Chevy clutch slave cylinder with a Toyota 3 speed transmission behind it. I installed a new clutch master cylinder while I was waiting for the rebuilt kit to come in for the original slave. It’s odd I can drive the truck in reverse no problem but when I go to put the truck in first gear and the let the clutch out the truck won’t go forward and stalls out as if the clutch Or clutch fork aren’t fulling engaging or disengaging. The slave cylinder seems to be a direct replacement of the the one I had on the truck but I had to re adjust the rod all the way out bc it was to hard to get the bolts lined up. The slave cylinder rod is really tight up again the clutch fork so not sure if I would have room to adjust it out. Wasn’t sure if it’s bc I have a new clutch master cylinder on there instead of the Tin cup master cylinder. Possibly doesn’t get the same amount of throw as the other. The truck will not roll in neutral either. If anyone has dealt with similar issues or has any suggestions I would really appreciate it.
