- Thread starter
- #141
I'm using a oil filter adapater out of a 98 Yukon 2 wheel drive. It has the vertical mount "normal" oil filter orientation. It also has the two ports for the oil cooler. Long time ago I bought a "kit" from B*M that had all the fittings and stuff to plumb for an oil cooler, I'm guessin its still around. Anway, there are two fittings that screw into the oil filter adapter and have -8 male ends, I also installed the same kind of fittings on the oil cooler. So you then make up some hose of your choice that has -8 female on one end and -8 hose connection on the other. Ran cooler lines from oil filter adapter, along the drivers side frame rail, then up through the radiator support and over to the cooler. We went with steel braided hose because I screwed up and did not get the right kind of fittings for the polyester braided hose I had.
I thought the fan belt was idiot proof , but I'm going to look at that again. Yes I have a new GM water pump that mataches the vehicle the engine came out of....98 Yukon. I did not think you could put the belt on wrong and it work?? Maybe so...I'll check that, I was in a hurry and just matched the smooth part of the belt with the smooth pulleys and the grooved with the groved pulleys. Maybe the belt install is not "Elbert proof"...
I expect that the truck will run around 195 or so, and like you say will hit about 210. I don't know why you would have a problem at 210F... with the electroncis & fuel control? I was concerned about running a 180 thermostat because I know some of these "new" engines need to run fairly hot for the electronics to function right and for the engine to go into closed loop. I may try a cooler thermostat once we figure what the hell is going on with the coolant flow.
I'm going to look pretty stupid if you can put the belt on wrong and it work....
I've not seen an engine do this before....so I'm sure it's going to be something oddball. We literally don't have coolant flow. I'll have to drag my @$$ for two weeks if I put that belt on wrong.
I'll take some pics of the fittings I used if you need that Devo.
The hole in the firewall is the same as where the A/C lines go through, but on the drivers side. Almsot looks like it was made for that. I'm using a B&M oil cooler, with -8 size hose to feed it.
