I've been lurking around this forum for a hot second now and you all have been an imense source of help with trying to fix up the 1977 FJ40 I've inherited. So, I'd like to first off thank everyone who contributes to this forum.
A little piece about my 40: as stated, it's a 1977 FJ40 that has (I believe) American racing wheels and a set of 32" Coopers (except the spare that's still the snow cruiser that came with it). Very early on in it's life, the 2F was swapped out for a Chevy 305 out of an El Camino with a 450 economaster and an Edelbrock intake. Everything else (save for the beetle washer reservoir and battery placement) is stock to my knowledge/experience. There's a laundry list of things that need to get fixed, refurbished and changed on this truck, but with winter around the corner, I want my FJ to be in good shape to wheel during it's first snowy winter since the 80s.
Currently, 4WD on the transfer case will not engage the front wheels. Spinning the rear wheels with the transfer case engaged spins the front drive shaft, and appears to spin at least the driver side axle (checking through the dif level check). Spinning the front drive shaft doesn't appear to spin the spline in the hub lock in either hub. Needless to say, engaging both hubs and spinning either wheel does not spin either the opposite wheel nor the drive shaft.
What I'm really looking for is guesstimating before I tear the hubs apart. Im not usually a big fan of throwing parts at a problem until it gets fixed. I want to figure out what's failed, and why. However, if I were to guess at this point, I'd lean towards a failed hub/birfield axle. My understanding is that the Warns in this era were not the best on these little trucks.
And, of course, just a few pics while it's in the air, I'll grab some more before I call it quits tonight.
