460-Add Crawl Control (CC) and Multi Terrain Select (MTS) to 2010-2019 models/all trims (4 Viewers)
Looking into the MTS/CC more now. A this point, thanks to others here, at a minimum I think I need the following for these features.
1 55936-60030 SWITCH, CTR CLUSTER $179.87
1 47217-60690 SOLENOID, Master CYL $886.07
2 89413-0C011 SENSOR, TRANSMISSION $111.72
If you are a 10-13 owner this is cheapest price for MTS I have found... I originally purchased mine here back in 2018...
~$136.70 as of today + around $10 shipping
$138.95 as of today + around $10 shipping
Shootz! Bought mine last year and installed. Maybe wait for a cheap CC?
Bell Lexus 12% sale is probably cheapest to get the two switch 090 crawl switch at around $282
Most sites overseas don't list this item for sale
If you want to save money and put up with the 4 switches
Carmarka with whatever they offer for shipping is probably cheapest
@Cruiser804
Glad you are still looking into this. It helps immensely when you have the rig in question and a commitment to research and find a solution. The solution here is going to be verified and confirmed by an owner of said vehicle and model year IMO.
It is a path of discovery that often isn’t easy with potentially lots of successes and failures.
Please continue to keep us posted how it goes.
55936-60030 SWITCH, CTR CLUSTER $179.87 55936E LH in the diagramView attachment 3189509
I saw this but I think there is a lot more than just the switch and dial to get it to work. My blackline has the DAC there on the dial vs the push button in this diagram so the plug behind it is likely not the same or not wired to the same ECUs. Given the MTS and CC are factory not dealer or port options this could mean the same as the 2020s with the booster, etc.
Agree, but hoping by at starting with the Luxury edition with MVP camera feature I already have the wiring. Again, I'm only going on what I can see in the EPC.
yeah, they made the blacklines simple so I doubt they have anything behind there. I am giving up on it unless someone has a cheap epiphany. When I build the 22 I will just gear and lock it vs worry about CC and MTS.
@Cruiser804
Make sure you have a functional Techstream install running when you get to that point.
This was previously posted but OBD port changed in 2020 and lost a pin or two. A ZPC could no longer be done with a paper clip after 2019 model year and TS is now the requirement for that procedure.
@Cruiser804
Copy. It'll be a few month before I get into this. Fairly cold where I live and would rather wait for some warmer whether before pulling the interior apart. Definately, gonna look closer at the ABS module to confirm which one I have.
CLICK ME: Crawl Control and Multi-Terrain Select (MTS) retrofit on '10-'19 GX 460 / all trims
Crawl control and/or MTS can be added to any '10-'19 GX 460 regardless of trim. MTS is not available in stock US models in North America except for Canadian top tier models. Crawl Control was available on '10-13 Premium models via special order packages and on '14-'19 Luxury models with the Driver Support Package. Five speed crawl is used in GX 460 like the '13+ LC & LX 570. Previous years of crawl in LC and LX 570 are three speed. Starting in 2020 MTS is available on US Luxury models with the “Off-Road Package”. '10-'19 Multi-Terrain Select includes modes for Mud & Sand, Loose Rock, Mogul, and Rock. 2020-2021 also adds Rock & Dirt and MTS AUTO mode. Part numbers and the ability to retrofit 2020-2022 models are unknown at this time.
What parts do I need?
PN: 859A1-60020 - 2010-2013 Multi Terrain Select (MTS) for any trim
PN: 859A1-60040 - 2014-2019 Multi Terrain Select (MTS) for any trim
PN: 84970-60070 - 2010-2019 crawl control for AVS/RAHC (adjustable shocks/rear air bag models)
PN: 84970-60090 - 2010-2019 crawl control for non-AVS/RAHC (adjustable shocks/rear air bag models) or vehicles in which stock AVS/RAHC has been removed
Genuine OEM Parts & Accessories | OEM Vehicle Parts - https://www.oemvehicleparts.com/ - CODE: GXORFIFTYOFF23 for 50% off “Shipping” / code can be used for any non-oversized Toyota/Lexus part(s) order
Installation threads on various forums
ClubLexus install thread
IH8MUD install thread
Multi Terrain Select Installation
Crawl Switch - Lifting the console to gain access to install area-VIDEO
Crawl Control Zero Point Calibration using OBD wire method-VIDEO
Crawl Control & Multi Terrain Select DIY Install-VIDEO
GX 460 Zero Point Calibration DIY Add Crawl Control
Technical Overview Info
Crawl Control technical-VIDEO
MTS technical-VIDEO
Multi Terrain ABS-technical overview covering different ABS "Braking" algorithms while off-road
Internal pictures of crawl switch
How to use MTS - Owner's Manual
Land Cruiser Prado 150 series owners check out info HERE
Budget or Stealth Crawl Control option (buttons or repurposed DAC switch)
A CL member posted these informative videos:
[Multi Terrain Select (MTS)]
2010-2013 (any trim)
PN: 859A1-60020
2014-2019 (any trim)
PN: 859A1-60040
[Crawl Control]
2010-2019 WITH adjustable shocks and rear air bags
PN: 84970-60070
2010-2019 WITHOUT adjustable shocks and rear air bags or converted to springs
PN: 84970-60090
•• If you purchase through oemvehicleparts.com there is a 50% off "shipping cost" offer with discount promo code: GXORFIFTYOFF
Alternative discount site in Japan for 859A1-60020 but currently not shipping.
•• 2020+ model year retrofit unknown at this time
Lexus GXOR - Crawl/MTS Info
EDIT: Good MTS install thread at CL.
EDIT: Do not utilize your VIN when searching out this mod as you may receive the incorrect part.
DAC versus Crawl Control - ClubLexus - Lexus Forum Discussion
Budget $20 Crawl Control
[MTS]
'10-'13 - 859A1-60020
80_img_7889_1c531901ca4231af86b0a988e0af52be57adf2e8_c1869efcfdad857742bdc4f0f564a8f8835da165.jpg
'14-'19 - 859A1-60040
[Crawl for AVS/RAHC models ]
'10-'19 - 84970-60070
80_img_7899_3dc2b789e03534a9a2d4420dfa6fa9622a2d3719_2c0522de38638fafe9f480c8510d60b45be39d46.jpg
[Crawl for NON AVS/RAHC models]
'10-'19 - 84970-60090
1_316ecfa453d54c35775e361666d4dc88cb0df1c9_80d3ed06356dacb78d00eeff0fb066b4bf37eb43.jpg
•• If you purchase through Genuine OEM Parts & Accessories | oemvehicleparts.com | OEM Vehicle Parts there is a 50% off "shipping cost" offer with discount promo code: GXORFIFTYOFF
(Amayama)
(IMPEX)
(Megazip)
(Motors Head Japan
(OEMVehicleparts)
(Megazip)
(OEMVehicleparts
(Amayama)
(Carmarka)
(Megazip)
(OEMVehicleparts)
(Megazip)
(OEMVehicleparts)
Genuine OEM Parts & Accessories | OEM Vehicle Parts - https://www.oemvehicleparts.com/ - CODE: GXORFIFTYOFF for 50% off “Shipping” / code can be used for any non-oversized Toyota/Lexus part(s) order (Parts sourced from JM Lexus in Margate, FL)
Maybe I missed this in the thread, when you add crawl Control and MTS to a 2020 plus model do you also gain the
  1. PANORAMIC VIEW MONITOR[5] WITH MULTI-TERRAIN MONITOR[6]
@GXAZ460 Unfortunately not without additional hardware.
I have the ECU for this but am fairly sure the wiring isn’t there in the far…far right area of the dash. A project pushed way back. You will see the camera option when you install MTS though. I also have a OEM front camera, factory grill for the camera/radar sensor, and the mirror cameras from bone yard parts. Might be possible to trigger with a separate switch but if you wanted to go OEM.. the steering wheel mounted camera button would be needed as well.
The camera I picked up had a cracked plastic cover so found a 3D print of the plastic cover I printed out. This would work for camera used in LC & LX as well in earlier 200 series years.
3D print replacement… I just used PETG
quick question guys, do i need to disconnect the battery on my 2019 gx before adding the MTS and CC options? thnaks
Quick answer: No.
I didn’t either but know that isn’t “best practice” from an electrical standpoint. :)
Mine has been converted for over 5 years now so no apparent long term effects if anyone is still on the fence.
I'm pretty sure when I was a mechanic the only time I ever disconnected batteries while swapping parts was for starters and alternators. Sometimes not even then.
ECUs don't really care.
