When I sprayed the concept, I found that the company called for a smaller tip than I could get good spray pattern from. So I asked a body shop friend, and he recommened adding a touch more reducer to thin it out. I spray primer with a 1.8 and the top coat with a 1.4
According to him, the paint should be done with the fast drips off a stir stick in 5 seconds. You may get a slow drip after that for sure, but not the drip drip drip bit.
After that, it works well.
because of compliance with EPA etc minimizes VOC, you will find a bit more reducer(which raises the VOC) and more air pressure(which raises the amount of paint that doesnt hit the truck and raises VOC) make for a better spray out with less orange peel.
Reducer temp range also helps reduce solvent pop. Warm temp reducer flashes off faster so if you get solvent pop try a higher temp range reducer.
It calls for between 1.3 and 1.6. I had a 1.4 in my other gun and I was having a lot of problems. It might have been the gun. It worked fine before.
The 1.8 was in my primer gun already from having just sprayed K38.
