40 series general tech and classifieds (4 Viewers)
Looking for a 40 hood and grill/bezel...they don't have to be from the same year or same truck or even match. Surface rust is fine, but not looking for anything that's been eaten through.
Would prefer non-split hood and round bezel...so something post '71 ish on the hood and pre '79 ish on the grill/bezel.
Thanks!
JT
Pretty much just a drivetrain refresh. The 1f runs and has good compression but leaks from every seal. It has a Weber 32/36 on it and want to swap back to Aisin carb. I would like to swap in later model axles to get disc brakes and the fine spline shafts so I can re-gear possibly. Lastly I want power steering.
My 62 axles wouldn't work for this application, right?
I think everything will work except the housing and the long side inner. What year is the 40 again?
I've a disc brake axle but l'm in Texas.
Thanks!
JT
@Texican might have what you need.
They had one at the premier of the Expedition Overland series in Dallas that was powered by a 1FZFE and it was NICE! they workmanship was there and the detail was great.
I have got to get on MUD more often!
Just wanted to put this here first. I have the 2f that came out of my truck when we did the motor swap. The motor was weak but running fine at that time. The compression across all cylinders were between 110 - 115 lbs. If anyone wants it give me a call $ 500.00 obo
What year did it come out of? Had it been desmogged? Factory carb and air cleaner?
