- Joined
- Jul 22, 2012
- Threads
- 639
- Messages
- 17,572
- Location
- Winter Park, Florida
- Website
- www.cruisermatts.com
I was hoping to be able to machine my 34mm case for lower gears as the old gears are worn out and I can’t find any new ones
What exactly is worn out on your gears?
And which gears haven’t you been able to find?
Like Georg said you can machine the 34mm case but it will punch thru the case and needs to have plates welded on. I’ve done this a few times on personal stuff. I’ve also opened up the bore in the case from 34 to 38mm a few times. If you have your own equipment this is fine but most don’t.
Another option that isn’t discussed often is buying a brand new bare 38mm housing (about $750) and send that to Georg (or me) to machine for the low gears.
You’d buy a 38mm rebuild kit which would have the idler shaft, all the bearings and seals, and re-use the shift forks and output shafts and output flanges from your 34mm case, or buy new.
