Straight from Advance Adapters website page for the 4.0:1 gearsets:
Note: This Gear set will also alter your high range ratio. The high range ratio will now result in a 10% underdrive."
4.0:1 Low Range Gear Set for 1980 - 1990 Toyota FJ60 Transfer Cases Having a 19 Spline Input Shaft and a 38MM Cluster Pin.This gear set is designed for the 38MM cluster pin case, however; we offer a stepped cluster pin that works for the 34MM case and u...
www.advanceadapters.com
What I was getting at, is that I would like to keep my high range 1:1 most likely, so that I can keep the most optimum highway cruising RPM for fuel efficiency and fuel range, and I would like to find a good low range gear set around 3.1:1 that does not underdrive the high range ratio.
