Another Interesting Car Care Nut video, in this case on the US build Tundra 3UR-FE and issue with timing chain tensioner. Wondering whether 0W20 pushed by the EPA is resulting in less oil pressure and possible issue with these tensioners not exerting enough force. Seems the rotor type oil pump and efficiency of the same to build pressure is better with 5W30.
Afterall the 3UR-FE was originally designed for 5W30 looking at the 200 series history and recommended oil for the 3UR-FE in many other countries.
Anybody has witnessed higher oil pressure on the dashboard gauge when switching from 0W20 to 5W30?
Maybe I see this wrong. Your thoughts please?
Chain Tensioners operated by oil pressure
3UR-FE oil pump
3UR-FE oil pump
